hier kommt die Frage eines Makro-Lehrlings
ich möchte in der aktiven Zelle bzw im markierten Bereich "\" durch "/" ersetzen, dass ist alles
(wenn es einfacher ist auch in der ganzen Spalte
das aufgezeichnete Mafkro ist so riesig und verstehen tu ich es auch noch nicht wirklich
sub repl_basl_2
rem define variables
dim document as object
dim dispatcher as object
args1(0).Name = "ToPoint"
args1(0).Value = "$E$5"
dim args2(1) as new com.sun.star.beans.PropertyValue
args2(0).Name = "By"
args2(0).Value = 1
args2(1).Name = "Sel"
args2(1).Value = true
dispatcher.executeDispatch(document, ".uno:GoDown", "", 0, args2())
dim args3(1) as new com.sun.star.beans.PropertyValue
args3(0).Name = "By"
args3(0).Value = 1
args3(1).Name = "Sel"
args3(1).Value = true
dispatcher.executeDispatch(document, ".uno:GoDown", "", 0, args3())
dim args4(17) as new com.sun.star.beans.PropertyValue
args4(0).Name = "SearchItem.StyleFamily"
args4(0).Value = 2
args4(1).Name = "SearchItem.CellType"
args4(1).Value = 0
args4(2).Name = "SearchItem.RowDirection"
args4(2).Value = true
args4(3).Name = "SearchItem.AllTables"
args4(3).Value = false
args4(4).Name = "SearchItem.Backward"
args4(4).Value = false
args4(5).Name = "SearchItem.Pattern"
args4(5).Value = false
args4(6).Name = "SearchItem.Content"
args4(6).Value = false
args4(7).Name = "SearchItem.AsianOptions"
args4(7).Value = false
args4(8).Name = "SearchItem.AlgorithmType"
args4(8).Value = 0
args4(9).Name = "SearchItem.SearchFlags"
args4(9).Value = 71680
args4(10).Name = "SearchItem.SearchString"
args4(10).Value = "\"
args4(11).Name = "SearchItem.ReplaceString"
args4(11).Value = "/"
args4(12).Name = "SearchItem.Locale"
args4(12).Value = 255
args4(13).Name = "SearchItem.ChangedChars"
args4(13).Value = 2
args4(14).Name = "SearchItem.DeletedChars"
args4(14).Value = 2
args4(15).Name = "SearchItem.InsertedChars"
args4(15).Value = 2
args4(16).Name = "SearchItem.TransliterateFlags"
args4(16).Value = 1280
args4(17).Name = "SearchItem.Command"
args4(17).Value = 1
dispatcher.executeDispatch(document, ".uno:ExecuteSearch", "", 0, args4())
dim args5(17) as new com.sun.star.beans.PropertyValue
args5(0).Name = "SearchItem.StyleFamily"
args5(0).Value = 2
args5(1).Name = "SearchItem.CellType"
args5(1).Value = 0
args5(2).Name = "SearchItem.RowDirection"
args5(2).Value = true
args5(3).Name = "SearchItem.AllTables"
args5(3).Value = false
args5(4).Name = "SearchItem.Backward"
args5(4).Value = false
args5(5).Name = "SearchItem.Pattern"
args5(5).Value = false
args5(6).Name = "SearchItem.Content"
args5(6).Value = false
args5(7).Name = "SearchItem.AsianOptions"
args5(7).Value = false
args5(8).Name = "SearchItem.AlgorithmType"
args5(8).Value = 0
args5(9).Name = "SearchItem.SearchFlags"
args5(9).Value = 71680
args5(10).Name = "SearchItem.SearchString"
args5(10).Value = "\"
args5(11).Name = "SearchItem.ReplaceString"
args5(11).Value = "/"
args5(12).Name = "SearchItem.Locale"
args5(12).Value = 255
args5(13).Name = "SearchItem.ChangedChars"
args5(13).Value = 2
args5(14).Name = "SearchItem.DeletedChars"
args5(14).Value = 2
args5(15).Name = "SearchItem.InsertedChars"
args5(15).Value = 2
args5(16).Name = "SearchItem.TransliterateFlags"
args5(16).Value = 1280
args5(17).Name = "SearchItem.Command"
args5(17).Value = 3
dispatcher.executeDispatch(document, ".uno:ExecuteSearch", "", 0, args5())
dim args6(0) as new com.sun.star.beans.PropertyValue
args6(0).Name = "ToPoint"
args6(0).Value = "$E$5"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args6())
end sub
könnte mir jemand zeigen wo und wie ich den Code auf das nötige kürze bzw ändere
mir ist dabei noch aufgefallen, suchen ersetzen funktioniert nicht, bei nur einer ausgewählten Zelle,
man muss die Zelle extra markiern um in dieser Zelle zu ersetzen ....hmmm
schonmal vielen Dank
