hier erstmal der Code:
Sub Abfrage
dim DatabaseContext as Object
dim DataSource as Object
dim Connection as Object
dim Statement as Object
dim Resultset as Object
dim Query as String
Query = "Select * FROM Daten"
DatabaseContext=createUnoService("com.sun.star.sdb.DatabaseContext")
DataSource= DatabaseContext.getByName("DB1")
Connection = DataSource.GetConnection("","")
Statement = Connection.createStatement()
Resultset = Statement.executeQuery(Query)
while ResultSet.next()
MsgBox ResultSet.getString( 1 )
wend
ResultSet.close()
Statement.close()
Connection.close()
end sub
Nun tritt dieser Fehler auf:
Type: com.sun.star.sdbc.SQLException
Message: Table not found in Statement (Select * from Daten)
Wo liegt der Fehler?
Danke für die Hilfe
Tschau
