Danke für deine Rückmeldung!
Also das is ein Teil des Codes aus dem Makro zum PDF Export:
'Export to pdf
dim args2(2) as new com.sun.star.beans.PropertyValue
args2(0).Name = "URL"
args2(0).Value = pdf_url 'This is equals to path and needed filename with "pdf" extension; but it is in URL format
args2(1).Name = "FilterName"
args2(1).Value = "calc_pdf_Export"
args2(2).Name = "FilterData"
args2(2).Value = Array(_
Array("UseLosslessCompression",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("Quality",0,90,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ReduceImageResolution",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("MaxImageResolution",0,300,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("UseTaggedPDF",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("SelectPdfVersion",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ExportNotes",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ExportBookmarks",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("OpenBookmarkLevels",0,-1,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("UseTransitionEffects",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("IsSkipEmptyPages",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("IsAddStream",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("FormsType",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ExportFormFields",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("HideViewerToolbar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("HideViewerMenubar",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("HideViewerWindowControls",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ResizeWindowToInitialPage",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("CenterWindow",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("OpenInFullScreenMode",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("DisplayPDFDocumentTitle",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("InitialView",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("Magnification",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("Zoom",0,100,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("PageLayout",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("FirstPageOnLeft",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("InitialPage",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("Printing",0,2,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("Changes",0,4,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("EnableCopyingOfContent",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("EnableTextAccessForAccessibilityTools",0,true,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ExportLinksRelativeFsys",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("PDFViewSelection",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ConvertOOoTargetToPDFTarget",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("ExportBookmarksToPDFDestination",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("_OkButtonString",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("EncryptFile",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("DocumentOpenPassword",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("RestrictPermissions",0,false,com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("PermissionPassword",0,"",com.sun.star.beans.PropertyState.DIRECT_VALUE),_
Array("",0,,com.sun.star.beans.PropertyState.DIRECT_VALUE))
Dim args18(2) as new com.sun.star.beans.PropertyValue
args18(0).Name = "URL"
args18(0).Value = pdf_url
args18(1).Name = "FilterName"
args18(1).Value = "calc_pdf_Export"
dim aFilterData(0) as new com.sun.star.beans.PropertyValue
aFilterData(0).Name = "Selection"
aFilterData(0).Value = ThisComponent.CurrentController.ActiveSheet
args18(2).Name = "FilterData"
args18(2).Value = aFilterData()
ThisComponent.storeToUrl(args18(0).value,args18())
dispatcher.executeDispatch(document, ".uno:ExportDirectToPDF", "", 0, args18())
'back to normal view
dim args16(0) as new com.sun.star.beans.PropertyValue
args16(0).Name = "NormalViewMode"
args16(0).Value = true
dispatcher.executeDispatch(document, ".uno:NormalViewMode", "", 0, args16())
'dim args17(0) as new com.sun.star.beans.PropertyValue
'args17(0).Name = "Nr"
'args17(0).Value = 3
'dispatcher.executeDispatch(document, ".uno:JumpToTable", "", 0, args17())
args1(0).Name = "ToPoint"
args1(0).Value = "$Q$3"
oDoc.removeActionLock()
oDoc.unlockControllers()
Unmittelbar davor werden per Filter die entsprechenden Positionen der Rechnung(snummer) zugewiesen und der Druckbereich festgelegt. Danach kommt eben dieser Code.
Danke noch mal!
