Makros per Kontextmenü ausführen
Forumsregeln
In angehängtem Beispiedokument findet man folgende Makros:
sub registerContextMenuInterceptor
    oController = ThisComponent.CurrentController
    oContextMenuInterceptor = CreateUnoListener("OOO_", "com.sun.star.ui.XContextMenuInterceptor")
    oController.registerContextMenuInterceptor(oContextMenuInterceptor)
end sub
function OOO_notifyContextMenuExecute(oContextMenuExecuteEvent as co.sun.star.ui.ContextMenuExecuteEvent) as variant
    oActionTriggerContainer = oContextMenuExecuteEvent.ActionTriggerContainer
    oMenuItem = oActionTriggerContainer.createInstance("com.sun.star.ui.ActionTrigger")
    oActionTriggerContainer.insertByIndex(0, oMenuItem)
    oMenuItem = oActionTriggerContainer.getByIndex(0)
    oMenuItem.setPropertyValue("Text", "rot")
    oMenuItem.setPropertyValue("CommandURL", "vnd.sun.star.script:Standard.Einfaerben.S_Set_red?language=Basic&location=document")
    oActionTriggerContainer.replaceByIndex(0, oMenuItem)
    oActionTriggerContainer.insertByIndex(1, oMenuItem)
    oMenuItem = oActionTriggerContainer.getByIndex(1)
    oMenuItem.setPropertyValue("Text", "gelb")
    oMenuItem.setPropertyValue("CommandURL", "vnd.sun.star.script:Standard.Einfaerben.S_Set_yellow?language=Basic&location=document")
    oActionTriggerContainer.replaceByIndex(1, oMenuItem)
    oActionTriggerContainer.insertByIndex(2, oMenuItem)
    oMenuItem = oActionTriggerContainer.getByIndex(2)
    oMenuItem.setPropertyValue("Text", "grün")
    oMenuItem.setPropertyValue("CommandURL", "vnd.sun.star.script:Standard.Einfaerben.S_Set_green?language=Basic&location=document")
    oActionTriggerContainer.replaceByIndex(2, oMenuItem)
    OOO_notifyContextMenuExecute = com.sun.star.ui.ContextMenuInterceptorAction.EXECUTE_MODIFIED
end function
sub S_Set_green
    osel = thiscomponent.currentselection
    osel.cellbackcolor = 32768'grün
end sub
sub S_Set_yellow
    osel.cellbackcolor = 16776960'gelb
end sub
sub S_Set_red
    osel.cellbackcolor = 16711680'rot
end sub
Diese erzeugen ein Kontextmenü mit drei Einträgen:
Das Makro
muss einmalig ausgeführt werden (Extras/Anpassen/Ereignisse), damit das Kontextmenü beim Aufruf um die drei Menüpunkte rot, gelb, grün erweitert wird. Für jedes mit dem Kontextmenü aufzurufende Makro, gibt es in der Function
einen Anweisungsblock. Hier den Index je Eintrag hochzählen, den im Kontextmenü anzuzeigenden Text eintragen und den Pfad zur aufzurufenden Routine.
rot_gelb_grün_Contextmenue.ods
(8.56 KiB) 2300-mal heruntergeladen
